You guys are the absolute best!!!
I cannot express enough how thankful I am. We got on a remote session and figured out the driver issue with my equipment and I'm up and running!!!!
What in the world do these errors mean and how do I fix them?
Error
Guiding Failed : FindMostProbaleHistoV !
I was able to calabrate but when I hit "Start" this is the error I get. If I fiddle with settings on the guide cam I can get it to work sometimes, but I have no idea why, usually by changing the binning. My guide cam is the ZWO ASI291mono mini
2nd error, after I platesolve from the main camera (ZWO 1600mm-cool) now I get this:
Telescope ASCOM, general error into order loop, hardware link dropped [EQMOD ASCOM Driver] -> SyncToTarget() RaDec sync was rejected
When that error appears Prism drops the connection to my mount completely. This one is super frustrating.
RESOLVED!! First night as license holder and just error after error
- Contact:
- Contact:
So I did a lot of searching and ended up on the french language forums using google translate. There was a user over there who was getting a bunch of strange error's also and I noticed that he mentioned switching from the ZWO native drivers to the ASCOM drivers for the camera's.
I tried that and BINGO, I was able to guide and able to finally sync the mount. So I am not sure what's up with that. I hope someone much smarter than me can figure that one out.
Now if I can just figure out why my platesolving is taking so long and giving me so many issues I think I might have a shot at getting this working.
- Contact:
Clear skies here tonight ( April/20/2019) I'm going to go back out and give it another round tonight.
If there's anyone who can help me out I'm in Central Time USA and I'd be willing to do a screen sharing type of internet meeting / call ( Zoom meeting or similar)
I'll be checking this forum periodically today and tonight.
- Contact:
Tonight's error - After platesolve completed and I click YES to sync
"Telescope ASCOM general error into order loop, harware link dropped [EQMOD ASCOM Driver] -> Cannot invert matrix with Determinant=0"
The typo exists in the error string so I left it in case someone has a match.
So I cannot build a pointing model tonight because prism drops the connection to the mount after it platesolves an image.
- Site Admin
- Contact:
This sounds like a bad sync problem, the driver has pushed back on the coordinates. Time and date ok in the driver?rottielover wrote: ↑Fri Apr 19, 2019 7:27 pmWhat in the world do these errors mean and how do I fix them?
Error
Hamza Touhami | Site Administrator
Hyperion-Astronomy.com
- Site Admin
- Contact:
I recommend cooling the camera well to reduce noise, use gain/offset that reduces noise and binning your images. Binning help reduce the size of the stars if you have bad focus, collimation issues, etc..rottielover wrote: ↑Sat Apr 20, 2019 1:48 pmSo I did a lot of searching and ended up on the french language forums using google translate. There was a user over there who was getting a bunch of strange error's also and I noticed that he mentioned switching from the ZWO native drivers to the ASCOM drivers for the camera's.
- Site Admin
- Contact:
I am here to help you this weekend, just let me know hyperion.astronomy@gmail.comrottielover wrote: ↑Sat Apr 20, 2019 2:42 pmClear skies here tonight ( April/20/2019) I'm going to go back out and give it another round tonight.
- Site Admin
- Contact:
worth investigating further, please reach out to me directly via email, I am here to help you.rottielover wrote: ↑Sat Apr 20, 2019 8:30 pmTonight's error - After platesolve completed and I click YES to sync
- Contact:
cannot thank Hamza enough. thank you thank you...
So couple things with my setup... 1 - I'm using two of the same brand camera's, the 1600 and the 290mini from ZWO. We switched one to the ASCOM driver and the other to the native ZWO driver, and that cleared up all the issues with guiding and platesolving
2- little more minor, but we tweaked my guider cam settings to use "Smooth Image" instead of 3x3 bin to eliminate hot pixels on the guider, and it's working very smoothly.
3 - also increased the DEC time to 15 seconds to help with the backlash.
Voila, I'm up and running!!
- Site Admin
- Contact:
You're welcome Sir, it was a pleasure to see you back and running.
