Setting up a local copy of Astrometry.net
Hardware and software setups, autoguiding and plate solving parameters, etc..
Post Reply
Hamza Touhami
Site Admin
Contact:
Fri Jun 02, 2017 3:54 pm
Hello everyone,
You can set up Prism V10 to use a local copy of the relaible Astrometry.net engine(Credit: Andy Galasso) for free, please follow these simple steps:
- Download the installer: http://adgsoftware.com/ansvr/ansvr-setup-0.20.exe
Run the installer
-Click Next or choose an alternate install location:
-Click Next or choose an alternate Start Menu folder name:
-Click Next or choose an alternate port number for ansvr:
-Click Install:
-Wait for files to extract. The progress bar will look like it is stuck in the middle for a long time. Be patient...
-Click Finish. You can leave both boxes checked.
Now you will download the astrometric index files that you need for your setup. Select the files you need and click Start. The files are very large (increasingly so for the narrower FOV indexes) and it can take a very long time to download them.
-Progress of the download is in a separate window. Close the window if you need to cancel the download. Next time you run the index file downloader, progress will resume where it left off.
Prism side installation: it is very simple to direct Prism to use the offline engine:
1. Click on the Settings menu on the top bar
2. Click on "Software Settings"
3. Click on the "Astrometry.net" tab
4. Set server type: ANSVR (Local Server)
5. API key: please click on the link at the bottom of the tab or go to: http://nova.astrometry.net to register for your own free key.
6.Open one of your images in Prism, right click on it and choose "Perform image center plate solve with Astrometry.net"
7. Your image will be plate solved using the local engine.
Please let me know if you have any trouble installing this great engine, your comments are always welcome.
Clear skies
Hamza Touhami | Site Administrator
Hyperion-Astronomy.com
Site Admin
Sat Jun 03, 2017 12:36 am
Great tuto !
Thanks Hamza!
Principal Prism Author,
Alcor-System
www.alcor-system.com
jackfd53
Thu Aug 24, 2017 3:50 pm
Hi...
Any time I try to use Astronmetry.net (locally or on the web) I get this error message...
"Astrometry.Net could not calibrate this image : PLUG-IN-ASCOM.AstrometryNet.Switch is not installed"
Any idea what this is all about? I'd emailed Bob about this before and never really got a satisfactory answer
Hamza Touhami
Site Admin
Contact:
Thu Aug 24, 2017 4:01 pm
Hello
There is a missing ASCOM component that you can download below, this will fix the issue. Let me know what you find out please.
https://www.dropbox.com/s/jjad4x2bwoy5k ... p.zip?dl=1
User avatar
DarkSky OnDemand
Contact:
Sun Aug 27, 2017 6:52 am
Hamza,
This is great information - I did the setup as shown and it works perfectly... Thanks!
-E
DarkSky Admin
https://darkskyondemand.com
Dark Skies and Phenomenal Seeing!
- Ed
DarkSky OnDemand
Hamza Touhami
Site Admin
Contact:
Sun Aug 27, 2017 11:12 am
You are welcome Sir, This provides a huge advantage to being perfectly centered in the field with no access to an internet connection. This marvel is here thanks for Andy Galasso, he genius is appreciated by all of us.
Richard McCall
Sat Sep 30, 2017 9:18 am
Having set up the local copy according to directions, I find that the plate-solving proceeds to the end but never opens the plate-solved image. Nor does it ask if I want to sync to the center of the plate-solved image.
This whole process works fine using the Astrometry.net remote server.
Any advise?
Thanks,
Richard
Hamza Touhami
Site Admin
Contact:
Sat Sep 30, 2017 12:39 pm
Hi Richard
Very strange bahavior, can you please perform these tasksL
  • Head over to this file and double click on it? i am using the default installation path here: C:\Program Files (x86)\Astrometry.net Local Solver\start_ansvr.bat
  • Please copy and paste the output of Astrometry.net in Prism in the window that appears on the top right
hopefully, this will get it resolved, please let us know how this fix works.
Thanks
Richard McCall
Sat Sep 30, 2017 2:27 pm
Thanks.
When I double click on that file I get a momentary opening of the command prompt screen which closes before I can paste anything into it.
I've tried re-installing the program but to no avail.
Richard
Hamza Touhami
Site Admin
Contact:
Sat Sep 30, 2017 2:42 pm
Thanks Richard
Double clicking on the file does start the engine and quickly disappearing DOS window is normal, I will reach out to you offline now.
P.S: Whatever solution we get to needs to be posted here to help others.
Richard McCall
Tue Oct 03, 2017 11:46 am
Here are some further details that might help in your analysis of the ansvr plug-in for Prism:
1) The log for the solving session produces the following output:
ansvr 0.19 start
loading config from /var/tmp/platesolve/config
read port 8080 from reg
using scale error override value 5 percent
using downsample 2
solution coordinates will use epoch J2000
saving config to /var/tmp/platesolve/config
can't setup server: Address already in use at /opt/ansvr/ansvr line 1318
waiting for data. . . (interrupt to abort)
2)The Astronomy.net output screen in Prism takes a considerable time processing "Plate solve image retrieval pending. . ." but then completes the process and reports "Retrieved plate solved image." However, no image appears.
3) I tried uninstalling and reinstalling the plug-in using Administrator privilege, but this had no effect.
4) I tried a different port assignment, but this had no effect.
Hamza Touhami
Site Admin
Contact:
Thu Oct 05, 2017 9:55 am
Good morning Richard
The plugin you are using ( which is posted here) seems to be out of date, i will post the updated one soon.
Thanks for your report.
Hamza Touhami
Site Admin
Contact:
Thu Oct 05, 2017 12:19 pm
Hi Richard
Please install the latest Astrometry.net plugin using the link below, Please report back after you install it to ensure proper operation.
Thanks.
Astrometry.net
Richard McCall
Thu Oct 05, 2017 12:57 pm
Sorry to say, but the new plug-in makes no difference. The solved image will not load in Prism using ansvr. According to the log, the plate-solve works, but the image never appears. I have tried the program on two computers with the same results.
I have checked for conflicts using the netstat command. I am now running ansvr on localhost 6000 as 8080 is used by TeamViewer. However, that has not solved the problem.
Both plug-ins (the original and the new one) work fine with the remote server, although the new one seems slower.
As I have internet access in my observatory, I will continue to access Astrometry.net remotely. I think ansvr is just too quirky to be of use.
Thanks for your help,
Richard
Hamza Touhami
Site Admin
Contact:
Thu Oct 05, 2017 1:52 pm
Richard
If understand you correctly, you want the local astrometry.net engine to output an annotated JPEG image of the solved image you are supplying to it after solving?
Richard McCall
Thu Oct 05, 2017 4:27 pm
Yes. Just as the remote server does. Is that not what the local engine does?
Hamza Touhami
Site Admin
Contact:
Thu Oct 05, 2017 6:34 pm
Good afternoon Richard
I have been using the local version for a great while and i do not think it will return the annotated JPEG, just the plate solved coordinates that i use to synchronize the mount.
Hope this helps.
Rev1: corrected spelling.
Richard McCall
Thu Oct 05, 2017 7:10 pm
Ahh! Thanks for the heads up.
I imagined that it did the same thing as the on-line version, especially since the output screen says that an image has been retrieved just as in the on-line version.
This is a confusion in the program. It really isn't a local version of the Astronomy.net plate-solver. It merely uses the Astronomy.net engine to return plate-solved coordinates.
User avatar
Vkagnihotri
Contact:
Sun Nov 26, 2017 10:07 pm
Awesome, I will try it soon..
https://adgsoftware.com/ansvr/
version **.0.20exe released..
:D
rottielover
Contact:
Fri Apr 19, 2019 10:22 am
Prism gave me an error that said something like "This is a Prism V11 feature" (Sorry this is from memory, I will edit tonight when I get home with the exact message). The other platesolving methods work fine, it's just when I try and ask it to use the Local install of astrometry.
cioc.adrian.dan
Sat Jun 08, 2019 6:32 am
A few days ago I updated Ascom Platform from 6.3 to 6.4 version. After the update the Astrometry.net platesolving both local and online stoped working. The error message is: PLUG-IN ASCOM.AstrometryNet.Switch is not installed.
How do I install it? Any ideas?
cioc.adrian.dan
cioc.adrian.dan
Sat Jun 08, 2019 6:33 am
This is the error in Prism
cioc.adrian.dan
Sat Jun 08, 2019 8:15 am
The solution: start the Ascom v6.4sp1 installer and choose repair platform. Who knew :)))
Hamza Touhami
Site Admin
Contact:
Sat Jun 08, 2019 11:51 am
I am a little late to this party :) , the plug-in itself,provided by others, has been flagged by windows defender and others. I am glad you figured out a way around it. thanks for the great tip Adrian
Post Reply
